Dear All,
Below is my script in workflow to perform http post request.
The above script is tested successfully in Postman.
But, I hit below error in Workflow:
Kindly assist.
Thanks and Regards,
Janice
Dear All,
Kindly assist.
Thanks and Regards,
Janice
Hello @CLTeh,
The reason why the below error occurs is because the FormData method is not available / undefined in neither JScript or Enhanced JScript.
[0002] W3603 : Error 0 on line, column 1: Microsoft JScript runtime error: 'FormData' is undefined
[0002] W3603 : Error running script.
[0002] Run Script: W1603 : Plugin failed - 14:51:00 (elapsed time: 00:00:00.005)
Please note that the below JavaScript code will also return an error as $ is also not available / undefined in neither JScript or Enhanced JScript.
$.ajax(settings).done(function (response) {
console.log(response);
Hi Janice,
maybe the following post helps. It is not the best approach but it works for me in a specific case where I had to use FormData.
Or maybe Phils post will be a better approach for you.
Regards
Thomas
