for example:
Company
name
adress
city postalcode
What if name is empty, is there a standard/buildin function to remove empty lines?
for example:
Company
name
adress
city postalcode
If you group all your address elements inside a single script with a suffix set to <br />? (when appropriate), then the entire address will be formatted properly since empty lines followed by a <br/> do not trigger a line feed.
You address block should look something like this:
sorry, wrong subject
Normally this works, but ran into this instance where it is not working as I expected.
Added the <br/> which I expected would work.
But the <br/> are considered literal strings
This is what the script is doing underneath the hood.
Running version 2021.1.2.2832
They set the output to text for some reason. After changing it to HTML it works. ![]()
