How to transfer my processes from old server to the new server 2022
Dear Team,
  1. I have recently performed a fresh installation on a Windows Server 2022, utilizing OL version 2025.1.1,7735. I need to transfer all my existing processes from the previous setup, which was on OL version 2023.2.0.6120 running on Server 2016, to the new server. Is there a method to achieve this, such as through Export and Import? Specifically, I need to migrate from Server 2016 to Server 2022 and from OL version 2023.2.0.6120 to OL version 2025.1.1,7735.
  2. Also, I have PlanetPress Design 7 installed on the Server 2016, Do I need to install PlanetPress Design 7 on the new server 2022 ?
Any assistance you can provide would be greatly appreciated.
Thank you,
Moh
Hello @akkakm,
This won’t be an easy question to answer without knowing what the current workflow configuration is and if there are any PlanetPress Design documents used in the current workflow configuration. I would recommend to submit a support ticket via our support portal to schedule a call with someone from OL Support to discuss the situation.
Note: In case PlanetPress Design needs to be installed on the same environment as OL Connect, the software needs to be installed in the order PlanetPress Design first → OL Connect and/or OL Connect Workflow second to ensure proper functionality.
Thanks a lot Marten for your reply, I appreciate your help.
Regards
akkakm
