how to save metadata as a file to incorporate into the exported PDF file name
I have entered metadata into the file name for the export before but it has been a long time since I have done that and cannot remember. I need to save the data I want as a metadata file so I can add it into the file name when the PDF is exported out of Planet Press. Can anyone help?
You need to add the tag that you want (the data that will be added as metadata) in the Job Creation settings…
Once in the Job Creation settings, check the “Include meta data” check box and go to the “Meta data Options” section. There you add your data at the level you need (that would be for you to figure out depending on how you will handle your output).
In your Output Creation settings, in your “Job Output mask”, you will be able to call on that metadata tag. See the following link.
