We’re trying to use the Database query plugin to read a counter value from a MySQL reference table and then update the table to increment the counter (AWB number).
However it seems there is no way to create a DSN for mysql event though we’ve installed mysql ODBC connector.
Is Mysql DB connection supported by PresConnect? is there another way to achieve this?
You have to create an ODBC-32 DSN because PReS Workflow is a 32 bit application. Once you have created that DSN, then DBQuery plugin will be able to use it.
I use the Dynamic SQL tab.
Select “Use dynamic values at runtime” and unselect “Expect record set”.
Click on the right icon to generate a new connection.
A new windows appears and here you create a new computer data source.
Thanks Phil, indeed it was indeed because we were using the 64-bit version of the ODBC mySQL connector.
We will now play a bit with DBQuery (as per Chris instructions) and Javascripts to see how this works.
