I run into the issue where the phone number field sent over with 0 and true phone number.
How could I ask to format this when the phone number field 0 to convert into this format 000-000-0000 and if the phone number is 9723106792 convert into 972-310-6792.
Below is what I have for the dash to added in but I cannot get the 0 for convert.
var field, result = “”;
field = record.fields[“HPhone”];
result=result.slice(0,3)+“-”+result.slice(3,6)+“-”+result.slice(6,10);
results.html(result);
if(field == 0) {
field = ‘0000000000’
I get error of missing after statement could you give more specific on code. Thank you.
if(field == 0) {
field = ‘0000000000’}
if(field == ‘0’) {
result=field.slice(0,3)+“-”+field.slice(3,6)+“-”+field.slice(6,10);
No does not work I have the same error message.
if(field == ‘0’) {
Please write the exact error…
“missing; after statement”
if(field == ‘0’) {
field = ‘0000000000’;
