My data source is a text file. In this text, I have a special character which says it is a breakpage. After extracting this data with the datamapper, how can I force the datadesigner to do a pagebreak ? Any idea ?
Please post you data here so I can look at it.
Hi Toch,
You will need to add an CSS class to your context_print-styles.css.
.after {
page-break-after: always;
In my test I targeted the first paragraph in a default template. But I’m sure this will get you started. I then added a script that checks a field for a certain value. Once the value is found the page breaks. The selector in the script is p which will target the only paragraph I have in my test template.
results.each(function(index){
var deposit = record.fields.Deposit;
if(deposit == “190.00”){
this.addClass(‘after’);
Hope this helps.
