I have to export my processes in DEV environment to PROD. I cannot use the “Send Configuration” because is two different environment and they don’t know each other. And I don’t have access to PROD. Normal situation in many companies…developer don’t have access to prod. So, how I can export my workflow and or specific processes in a workflow?
You can simply save your config, copy it over to the other system and use the Import option from the file menu to select which processes to import. If you don’t have access to the PROD system, someone who does will have to perform the import for you.
