How to break up a section properly (with page-break-before?)
I have a document where I want the last section to appear on the next page completely, which works for the most part by using: page-break-before: always. Except when the section is too big to fit on a single page. Then an empty page is shown and then the section appears, but it is still broken up correctly. I want to avoid having this empty page.
So, what I expect is to have the first page, without this last section as it is forced onto the next page. Since this section is too large to fit on a single page what can be shown will be shown on the page and the rest is broken off onto the next page. I use a <span> for this section so it is allowed to be broken up. Using a <p> instead does not seem to change anything. And a <div> will absolutely not work as this will not be broken up at all and causes an error instead.
Is there a way to do this?
Would be easier if you could provide a anonymized reproducible Template and Datamapper so we can play aroudn and see wheree hte problem lies.
Feel free to reach me in private should you wish to share your documents.
Sorry for interfering if this is already being handled in private messages, I just want to say that you probably should use an <article> instead. The page-break-before style is not supported for <span>.
The result is the same if I use an <article> instead. It will take me some time to anonymize the data.
Just in case it saves you some time, this is a simple test template I cobbled together earlier. I assume I’m doing something different since I don’t see a blank page.
Article.OL-template (7.6 KB)
Hi Sander,
If you add enough text on the first page where it still fits but there is not enough room to fit a new line and see what happens. An empty page is added after this before the <article> section begins. Shouldn’t the <article> section begin on the new page without an empty page being created in between?
You’re right, I would not expect to see a blank page in that case. That looks like a bug to me.
It is no longer reproducible with the next major update of Connect where we reworked that code, so perhaps we could (partially) backport that. I will create a ticket.
As for a workaround, it seems to behave better if the page-break-before style is changed to page-break-after and moved to a dummy <div> that is placed before the <article>:
Article2.OL-template (7.7 KB)
