I have two systems: Development and Production Servers. Unfortunately both servers are not up to date with the same version of the workflow configuration. So I can’t send the Workflow configuration of the Development Server to the Production Server.
Usually we import only the processes we need into the production configuration and we send this configuration to the local workflow service.
This works fine most of the times when there is no running job; however when our end of month billing process is running, the service takes hours to stop and start. At times, we have had to kill the service which caused loss of data.
Is there any other way of sending the configuration in such circumstances. If I was to Pause the service and then send the configuration, would that work without interrupting any job that is currently running?
Is there a feature whereby a single process within the Dev server workflow configuration can be selected and sent from the Developement Server to the Production Server?
