Where do I point the browser to access the GUI and start creating flows? After the installation the browser launched automatically but now I can’t recall the correct URL.
Hi @pacel,
By default you can access the GUI via your web browser via the URL: http://127.0.0.1:1881/ or, in case of HTTPS, via the URL: https://127.0.0.1:1881
Probably over-engineered solution for when you forget which port is used by Node-Red (but hey, it was fun to cobble it together!):
- Open a command line window
- Copy/paste the following command (on a single line) then press enter:
for /f "tokens=2" %i in ('tasklist ^| findstr "node"') do @for /f "tokens=2" %j in ('netstat -aon ^| findstr "%i"') do @echo %j - You should get a response similar to
0.0.0.0:1880, where1880is the port used by Node-Red.
I warned you it was over-engineered… ![]()
My good friend @Erik reminds me that you can always examine the contents of the settings.js file in the C:\Program Files\Objectif Lune\Node-RED\Node-RED\node_modules\node-red folder.
Well… yeah… sure… if you want to be lazy about it and take the easy way out.
But some of us prefer the over-engineered way, and that’s that. ![]()
