how can I add a dynamically created 'canvas' - object to the page?
To create some very customized output, I need to create and add a ‘canvas’ object to a template.
The following code needs to be executed:
        var canvas = document.createElement('canvas');
        canvas.setAttribute('width', 100);
        canvas.setAttribute('height', 100);
        var ctx = canvas.getContext('2d');
        ctx.fillStyle = 'rgb(0,0,0)';
        ctx.strokeRect (25,25,10,10);
        document.body.appendChild(canvas);
In the scripteditor, I get the information that “document” is unknown.
How do I have to modify the code to get it work?
Hello Thomas,
The issue here is that you’re trying to display something in the browser but you’re doing it in the server-side version of the scripts. If you, instead, create a new __Java__script resource from the Resources pane, then you will get exactly the same capabilities you would in your browser. If you take a look at some of the Foundation Web template wizards (such as the Jumbotron), you’ll see that the javascript resources include jQuery and some other javascript libraries: these scripts are added to the <head> tag of the generated output. This works for print and web contexts only.
Thinks of Scripts as something like node.js, or php, or ASP.net - it’s run on the server, not in the browser.
Thanks - can you provide an example file for this, too?
Hi Thomas,
As complement to what Evie has said, if you want to try your example given above in your question, you can:
create and add a “canvas” object to a template: use script in the panel scripts
in Selector write body
check Selector
and in the editor write :
results.append('&lt;canvas id="myCanvas" width="200" height="100" style="border:1px solid #000000;"&gt;&lt;/canvas&gt;');
to draw graphic on this canvas, you can create a new javascript in the folder Javascript in Resources and write these instructions:
$(document).ready(function(){
    var ctx = $("#myCanvas").get(0).getContext('2d');
    ctx.strokeRect (25,25,50,50);
don’t forget to save the javascript file and include it in your web section.
Note: You can’t see the result in preview, But only in live or clicking on Preview HTML icon in the rubon of the designer
I hope that this help you
Hi Fadila,
it’s a step further… but still something is wrong.
I can see the appended canvas in the output, but the code in the JavaScript file seems not to be executed.
The JavaScript file is included for the section (checkmarked there ) in Printing context; it was the default newly created template.
I am using the Preview HTML-Icon first wih IE now with FF - only can see the border of the canvas.
If you have a complete template file that works on your system, I’d be glad to get it.
Thanks in advance.
EDIT: in the console from FF I get a message saying:
ReferenceError: $ is not defined
Do I have to include anything else before?
Hello Thomas,
Canvas are used in HTML5 for graphics and animation on the web. So use your example in a web template or context
