Hi - I have a stacking bar chart. I want to hide the highlighted gridlines below. I tried using ‘gridAlpha’: 0 and ‘gridColor’: #FFFFFF in the CategoryAxis section of the graph and it does nothing. I tried changing the color lines to white and it does nothing. My code is below also. I have tried everything that I can think of. I can do on a regular bar chart where I am not stacking the data. Please help!!
function Graph(field, title, color) {
this.field = field;
this.title = title;
this.color = color;
function getCopy(sourceArray, index) {
let source = sourceArray[index % sourceArray.length];
let target = {};
for (let prop in source) {
target[prop] = source[prop];
return target;
if (results.length) {
var chartData = [];
chartData.push({
'value_label': "0%",
'values_1': record.fields['DefPpt0'],
'values_2': record.fields['AE_DefPpt0']
chartData.push({
'value_label': "1%",
'values_1': record.fields['DefPpt1'],
'values_2': record.fields['AE_DefPpt1']
chartData.push({
'value_label': "2%",
'values_1': record.fields['DefPpt2'],
'values_2': record.fields['AE_DefPpt2']
chartData.push({
'value_label': "3%",
'values_1': record.fields['DefPpt3'],
'values_2': record.fields['AE_DefPpt3']
chartData.push({
'value_label': "4%",
'values_1': record.fields['DefPpt4'],
'values_2': record.fields['AE_DefPpt4']
chartData.push({
'value_label': "5%",
'values_1': record.fields['DefPpt5'],
'values_2': record.fields['AE_DefPpt5']
chartData.push({
'value_label': "6%",
'values_1': record.fields['DefPpt6'],
'values_2': record.fields['AE_DefPpt6']
chartData.push({
'value_label': "7%",
'values_1': record.fields['DefPpt7'],
'values_2': record.fields['AE_DefPpt7']
chartData.push({
'value_label': "8%",
'values_1': record.fields['DefPpt8'],
'values_2': record.fields['AE_DefPpt8']
chartData.push({
'value_label': "9%",
'values_1': record.fields['DefPpt9'],
'values_2': record.fields['AE_DefPpt9']
chartData.push({
'value_label': "10%",
'values_1': record.fields['DefPpt10'],
'values_2': record.fields['AE_DefPpt10']
chartData.push({
'value_label': "11%",
'values_1': record.fields['DefPpt11'],
'values_2': record.fields['AE_DefPpt11']
chartData.push({
'value_label': "12%",
'values_1': record.fields['DefPpt12'],
'values_2': record.fields['AE_DefPpt12']
chartData.push({
'value_label': "13%",
'values_1': record.fields['DefPpt13'],
'values_2': record.fields['AE_DefPpt13']
chartData.push({
'value_label': "14%",
'values_1': record.fields['DefPpt14'],
'values_2': record.fields['AE_DefPpt14']
chartData.push({
'value_label': ">15%",
'values_1': record.fields['DefPpt15'],
'values_2': record.fields['AE_DefPptOVER14']
var config = {
type: "serial",
categoryField: "value_label",
rotate: false,
dataProvider: chartData,
graphs: [{
"valueField": "values_1",
"type": "column",
"fillAlphas": 1,
"fillColors": "#232c68",
"lineThickness": 0
"valueField": "values_2",
"type": "column",
"fillAlphas": 1,
"fillColors": "#6da141",
"lineThickness": 0
"valueAxes": [{
"id": "ValueAxis-1",
"stackType": "regular",
"title": ""
"categoryAxis": [{
"id": "CategoryAxis-1",
"gridAlpha": 0.0
results.attr('data-amchart', JSON.stringify(config));
