Occasionally, the PlanetPress generated trailer page show these funky glyphs.
The process adds a trailing page with information about the job. The elements with the funky glyphs is data extracted from the PDF.
Hi, this could be an issue with the font encoding of the PDF.
You could try to recreate a PDF with Acrobat Distiller, or other tools.
Also did you tried to extract with the lastest Connect version?
The PDF files (%PDF-1.5) are the input data, so I don’t have control over their creation.
Used PPC v2021.2 to extract with and have not tried PPC v2022.1.
I did try saving the PDF with a couple other PDF tools, but without any difference.
It might be related to Acrobat Extended Features, but not exactly sure what these are.
When I open the PDF files (with the funky glyphs) with a viewer, I get a dialog.
What happens if you select and copy the text from the PDF using Acrobat Reader and paste it in Notepad? That’s usually a good rule of thumb to determine whether text can be extracted to start with or not.
