Hi
We have a job which comes in as a colour PDF but we want to output as mono\Black & White. Is there anyway to do this as can’t really see much in terms of output settings for colour space etc
James
Hi
James
maybe pdf24 is an option? You can create a pdf printer driver and setup a gray output profile. In Connect output you can choose that printer driver.
Of course there are some bad things:
I have never used it for productive purposes, so you will have to decide for yourself if it is a good solution.
Hi James,
If your working with a PostScript printer and your PPD has color mode code in it you can specify that color mode via the dynamic PPD options in the same way you would to pull trays or activate a stapler. If you would like to go over this in more detail please feel free to contact support.
Alex
Hi Alex, It’s PDF unfortunately as we are then running it back through PReS to apply the artwork which needs to be in colour
