First datamapper condition always True with the Merge PDF-componentet
When using the Merge PDF-component and a datamapper with conditional steps the first condition in the datamapper always evaluate to True even if it’s not.
Using the same datamapper with Folder Capture-plugin the conditions in the datamapper works as intended.
Is this expected behavior or are there any workarounds?
PReS Workflow version: 8.3.2.10114
PReS Connect Designer: 1.3.2.32220
Hi Skomsoy,
I tried something by my side and it works as expected, what kind of condition are you testing? How is setting up this data mapper?.. your description is very general.
To have a more understanding of your particular case, I suggest that you report your issue at Document composition and automation | Upland Objectif Lune
Best Regards,
Juan
