Filter Records in Connect / Datamapper
Is there a way to filter records for a specific field on connect before exporting it as a PDF? E.G. if we have a field called “Proof Flag” and some records are marked as “Proof” in that column, is there an option to do so and still keep data in sequential order? I know it can be done when you’re outputting a pdf.
You could use the Skip to next record Action.
Setup your condition and when you get the Proof value, you skip to the next record. Therefore, they won’t be part of the records.
