Not sure I understand. Are you trying to create a detail table of Colors per record? Meaning you need to iterate on the same line? Ok Proceed as follow:
Add an Action step to extract the array of colors with the expression
var arrColors = data.extract(10,65,0,1,“<br />”).trim().split(" ");
Add a Repeat step:
set repeat type to “Until statement is true”
Maximum iterations on each line to : parseInt(arrColors.length);
Condision based on JavaScript with expression: parseInt(steps.currentLoopCounter);
Operator: is equal to
Right hand operator based on JavaScript with expression: parseInt(arrColors.length);
Inside the Repeat Step, insert a Condition step
Based on JavaScript with the expression: parseInt(steps.currentLoopCounter);
Based on Value
Value: 0
In the True branch of the above condition, Add an Extract step:
set the Mode to JavaScript with the expression: arrColors[parseInt(steps.currentLoopCounter)-1];
In the False branch of the condition:
Add a GoTo step with Target type: Line; from Current position and Move by -1
Add an Extract step and set the Mode to JavaScript with the expression: arrColors[parseInt(steps.currentLoopCounter)-1];
After the Condition but still within the Reapeat loop, make sure your Go to step Moves by 1 (line)
I obviously don’t know what your end goal is, here, but it may be simpler to just extract the entire line and convert it to a JSON string that you store in a field in your record.
Then whenever you want to use it in the template, you simply iterate through the JSON string. You’d just use a Javascript Extraction step with something like this:
var jsonColors = ;
var aColors = data.extract(12,81,0,1).split(" ");
for(var i = 0; i < aColors.length; i++){
if(aColors[i]){ //logger.info(aColors[i]);
jsonColors.push(aColors[i]);
} //logger.info(JSON.stringify(jsonColors));
JSON.stringify(jsonColors);
This gets you nice little strings like [“red”,“green”,“blue”]
hi, we have complex templates developed using csv and xml data. our sister company is also providing the same data in text format. spent weeks trying to figure out how to create a detail table out of array of fields. this exemple has saved me the trouble of redevelopping my templates using text data to match the csv and xml data models already in place. i think a new feature allowing the goto step to move left or right might also be beneficial. perfect.thanks
