I need to create a companion file for each PDF generated by PReS with the following fields:
Docno
start-page
end-page
Customer Name
Number of Images
Number of paper pages
I think this needs to be done as after the PDF output is generated since that would be the only way to determine the start-end pages and number of paper pages for each record.
Any help/tips would be greatly appreciated.
TDGreer
September 20, 2019, 5:40pm
2
Can you clarify what you mean by “Number of Images” and “Number of paper pages”?
For the rest, you can certainly get data about media into/out of MetaData. Heres’ a script that I use, I think Phil provided it originally.
var xhttp = new ActiveXObject("Microsoft.XMLHTTP");
var metaFile = new ActiveXObject("MetadataLib.MetaFile");
metaFile.LoadFromFile (Watch.GetMetadataFilename());
var metaJob = metaFile.Job();
var metaGroup = metaJob.Group(0);
var totalPages = 0;
var documentPages = 0;
var documentCount = 0;
var mediaName;
var mediaCount;
var mediaMap = {};
var contentsetid = Watch.ExpandString("GetMeta(_vger_contentset_id[0], 10, Job.Group[0])");
var url = "http://localhost:9340/rest/serverengine/entity/contentsets/" + contentsetid + "/pages?detail=true";
xhttp.open('GET',url,false);
xhttp.setRequestHeader('Content-Type', 'application/json');
xhttp.onreadystatechange = handlerGetDataRecord;
xhttp.send();
Watch.SetVariable("totalPages", totalPages);
Watch.SetVariable("sheetCount", totalPages / 2);
Watch.SetVariable("documentCount", documentCount);
Watch.SetVariable("mediaCount", JSON.stringify(mediaMap));
function handlerGetDataRecord()
if (xhttp.readyState == 4) {
if (xhttp.status == 200) {
var contentsetPageDetails = JSON.parse(xhttp.responseText);
var contentsetPageDetailMap = {};
documentCount = contentsetPageDetails.length;
for (var idx=0; idx < contentsetPageDetails.length; idx++) {
for (var pdx=0; pdx < contentsetPageDetails[idx].pages.length; pdx++) {
documentPages += contentsetPageDetails[idx].pages[pdx].count;
mediaName = contentsetPageDetails[idx].pages[pdx].media.name;
if(isNaN(mediaMap[mediaName]))
mediaCount = 0;
else
mediaCount = mediaMap[mediaName];
mediaCount += contentsetPageDetails[idx].pages[pdx].count;
mediaMap[''+mediaName] = mediaCount;
contentsetPageDetailMap[''+contentsetPageDetails[idx].id] = documentPages;
documentPages = 0;
mediaName = '';
mediaCount = 0;
for (var idx=0; idx < metaGroup.Count; idx++) {
var contentItemId = metaGroup.Item(idx).FieldByName('_vger_contentitem_id');
// metaGroup.Item(idx).Fields.Add('_vger_fld_pndPAGECOUNT', contentsetPageDetailMap[contentItemId]);
totalPages += contentsetPageDetailMap[contentItemId];
metaFile.SaveToFile (Watch.GetMetadataFilename());
I create my own JSON file via Create File after the Run Script task:
{"filename":"%{filename}","pages":%{totalPages},"sheets":%{sheetCount},"documents":%{documentCount},"media":%{mediaCount}}
Thanks for the feedback!
I am getting the following error:
[0012] W3602 : Error 0 on line 24, column 1: Script.NamedItemWatch: Variable does not exist.
Any ideas?
Very much appreciate any assistance.
Thanks!
TDGreer
September 20, 2019, 9:32pm
4
The script sets the values of the various counts into Watch Local Variables. So, you need to create all the referenced Local Variables.
That did the trick!
I needed the information at the record level (detail per record) rather than at the job level (Summary), so I created a few arrays and saved the array to the local variable.
Can you think of a more efficient way to approach this?
TDGreer
September 24, 2019, 4:57pm
6
Not off hand, no. Whatever works!
