Is it somehow possible to extract rotated data from a PDF. Sure I can possibly rotate the pdf file and then extract the data, but then I will need to rotate the page back for the rest of the extractions.
Anys suggestions?
Anys suggestions?
Hi Hubert,
Have you taken a look here? There are scripts that can be used in Workflow to rotate landscape pages prior to data mapping.
Hope that helps.
Thanks for you suggestion. However these are portrait documents where a value is printed at a -90deg angle and the rest is printed landscape. I was only wondering if it was possible to extract rotated data from a PDF without having to rotate the document first.
