Hi all, hope all is well.
As always, I’m looking for a nod in the right directions. I’m getting an error message on OL Connect Image after changing the working folders over from C: to E:
I am using a simple workflow on 2025.1.
Folder capture
Set variables (three)
Create MetaData
OL Connect Image output (email with attachment).
Previous builds I have used have accomplished this quickly. I have moved to a new cloud server and am running 2025.1. The speed of processing seems to have dropped drastically. The only difference I can see in build (as I am now running on a faster machine) is that all the working folders still point to C:
I have followed the online guide to move the folders by adding the reg. key.
When I restart and run the workflow, I get the following errors from Image:
REQST: PPImage Request - 1:53:45 PM
INFO: Processing file E:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Image\QueuedJobs\6D072.ps
DEBUG: Reading job options from input file E:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Image\QueuedJobs\6D072.ps
DEBUG: Watch Process Name : TEST_010P4A78XEHQ24D
INFO: Starting conversion…
INFO: Initializing PlanetPress Alambic…
INFO: Distilling file to Filename9000001.pdf…
DEBUG: %%[ Error: invalidfileaccess; OffendingCommand: file ]%%
DEBUG:
DEBUG: Stack:
DEBUG: (w)
DEBUG:
DEBUG: (E:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Image\Spool\6D072\Filename9000001.pdi)
DEBUG: /FO
DEBUG:
DEBUG:
DEBUG: %%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
DEBUG: %%[ Warning: PostScript error. No PDF file produced. ] %%
ERROR: I1007 : Error while converting to PDF : Error converting file: invalidfileaccess
ERROR: I1005 : Error while processing job; moving file to error folder: 6D072.ps
REQST: End time: 1:53:56 PM (elapsed time: 00:00:10:721)
Is someone able to nudge me in the right direction please.
Dav
