I deleted a table while in preview mode. The designer tab went completely grey and this error message popped up:
After I clicked “okay” Designer tab comes back, but table is not deleted.
Stacktrace:
Cannot invoke "org.mozilla.interfaces.nsIEditor.getSelection()" because the return value of "com.objectiflune.application.designer.editors.HtmlEditor.getInternalEditor()" is null.
java.lang.NullPointerException: Cannot invoke "org.mozilla.interfaces.nsIEditor.getSelection()" because the return value of "com.objectiflune.application.designer.editors.HtmlEditor.getInternalEditor()" is null
at com.objectiflune.application.designer.internal.handlers.g.run(g.java)
at com.objectiflune.application.designer.editors.internal.SourceEditor.withoutUndo(SourceEditor.java)
at com.objectiflune.application.designer.editors.HtmlEditor.lambda$22(HtmlEditor.java)
at com.objectiflune.application.designer.editors.v.run(v.java)
at com.objectiflune.application.designer.editors.bh.run(bh.java)
at com.objectiflune.application.designer.shared.d.run(d.java)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at com.objectiflune.application.designer.editors.bi.run(bi.java)
at com.objectiflune.application.designer.editors.HtmlEditor.withoutRedraw(HtmlEditor.java)
at com.objectiflune.application.designer.editors.HtmlEditor.runUnmerged(HtmlEditor.java)
at com.objectiflune.application.designer.editors.TemplateEditor.runUnmerged(TemplateEditor.java)
at com.objectiflune.application.designer.editors.HtmlEditor.a(HtmlEditor.java)
at com.objectiflune.application.designer.editors.HtmlEditor.commitChanges(HtmlEditor.java)
at com.objectiflune.application.designer.editors.HtmlEditor.commitUndoableChanges(HtmlEditor.java)
at com.objectiflune.application.designer.internal.handlers.DeleteTableHandler.execute(DeleteTableHandler.java)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:317)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:251)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:485)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:438)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:449)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:475)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4054)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3642)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:643)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:550)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:171)
at com.objectiflune.application.Application.start(Application.java)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
at org.eclipse.equinox.launcher.Main.main(Main.java:1440)
