Error message in node-red olconnect.error
Hi guys,
I’m trying to process a big data file via the connect server in node-red, but I get the below error message.
“olconnect.error.ERR_FR_MAX_BODY_LENGTH_EXCEEDED”
Is there a way to bypass this limit or atleast a workaround? I know I can split the data file up in chunks but I would try not to if possible there can be a solution.
Thank you for your help in advance.
Hi James123456,
I’ll run this by the Automate team. Is there any relevant information in the OL Connect Server log? What is the size of the data file?
Best,
Hi @Erik,
The data file is about 64MB in size.
The below is the error from the server log:
Not that familiar with error log codes but this one seem to stand out “Early EOF (SRV000084)”. Maybe will help.
[2024-03-15 09:15:44,860] ERROR [qtp441260727-248769] com.objectiflune.serverengine.rest.database.FilestoreRestService.a(FilestoreRestService.java) An error occurred while uploading ****REDUCTED**.txt to the filestore caused by EofException: Early EOF (SRV000084)
org.eclipse.jetty.io.EofException: Early EOF
	at org.eclipse.jetty.server.HttpInput$3.getError(HttpInput.java:1207)
	at org.eclipse.jetty.server.HttpInput$3.noContent(HttpInput.java:1195)
	at org.eclipse.jetty.server.HttpInput.read(HttpInput.java:333)
	at java.base/java.io.InputStream.read(Unknown Source)
	at org.glassfish.jersey.message.internal.EntityInputStream.read(EntityInputStream.java:74)
	at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:1309)
	at org.apache.commons.io.IOUtils.copy(IOUtils.java:978)
	at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:1282)
	at org.apache.commons.io.IOUtils.copy(IOUtils.java:953)
	at org.apache.commons.io.FileUtils.copyToFile(FileUtils.java:1043)
	at org.apache.commons.io.FileUtils.copyInputStreamToFile(FileUtils.java:952)
	at com.objectiflune.serverengine.rest.database.FilestoreRestService.a(FilestoreRestService.java)
	at com.objectiflune.serverengine.rest.database.FilestoreRestService.uploadDataFile(FilestoreRestService.java)
	at jdk.internal.reflect.GeneratedMethodAccessor400.invoke(Unknown Source)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52)
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:134)
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:177)
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:176)
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:81)
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:478)
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:400)
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81)
	at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:256)
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248)
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244)
	at org.glassfish.jersey.internal.Errors.process(Errors.java:292)
	at org.glassfish.jersey.internal.Errors.process(Errors.java:274)
	at org.glassfish.jersey.internal.Errors.process(Errors.java:244)
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265)
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:235)
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684)
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:394)
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:346)
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:358)
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:311)
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:205)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
	at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656)
	at com.objectiflune.serverengine.rest.security.MethodTypeFilter.doFilter(MethodTypeFilter.java)
	at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
	at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1626)
	at org.eclipse.jetty.servlets.CrossOriginFilter.handle(CrossOriginFilter.java:319)
	at org.eclipse.jetty.servlets.CrossOriginFilter.doFilter(CrossOriginFilter.java:273)
	at com.objectiflune.serverengine.rest.security.LicenseFilter.doFilter(LicenseFilter.java)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:552)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
	at org.eclipse.jetty.server.Server.handle(Server.java:516)
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
	at java.base/java.lang.Thread.run(Unknown Source)
Our devs were able to trace it down, we will address this in 0.9.12. To workaround the problem you could apply the following change to the OLConnectRestClient.js file located here:
C:\ProgramData\Objectif Lune\.node-red\node_modules\@objectif-lune\connect-rest-client\dist\api\OLConnectRestClient.js
Navigate to line 309 and add the following before the ‘beforeRedirect’ code to raise the limit to 96MB:
httpRequestOptions.maxBodyLength = 96000000;
Save the file and restart OL Connect Automate/Node-RED. I tested it on my local install and it solved the problem for me.
Hope this helps,
@Erik, that fixed the issue. Thank you.
