Error is happend on the process of Create Job
Hi there,
I am encountering an issue in a flow that reads and processes XML files.
When the input file size is 1.2 MB, the process completes successfully, but when the file size is 5 MB, an error occurs at Create Job.
Does anyone know the possible cause and how to resolve this issue?
Below are the details from the Event Viewer.
The description for Event ID 1 from source PPWatch8 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Hello @Kiyomi_Kokubun,
Can you please share the error that is logged in the Connect Workflow logs? Following is the location where the Connect Workflows logs (ppw*.log) are located:
C:\ProgramData\Objectif Lune\PlanetPress Workflow 8\PlanetPress Watch\Log
