Error in the Print result - the option Rotate document: 180 degrees do not behave as expected.
Good Day,
I am designing a 4 - up print template. The dimensions of the post-card are: width: 8.5 in and height: 5.5 in
The final media size will be tabloid but in portrait orientation: width: 11 in and height: 17 in. The fit 4 post cards on the final media correctly, I need the tabloid to set as landscape - width: 17 in and height: 11 in. I put check mark in the option: Rotate document 180 degrees. I print template as a PDF since I am just creating a demonstration for the purpose of training. The end result is PDF where the tabloid page is landscape so the title of the option is incorrect: the correct title should be: Rotate document 180 degrees or this option is not behaving the correct way. I hope this will be corrected at one point.
Thank you
Hello Frank,
This is unfortunately a known issue, the document is being rotated 90 degrees instead of 180 degrees. This will be fixed in a later version of the software (I’m not sure in which one, as this issue is currently still open). Note that the option is correctly titled, but is currently not rotating with the right value.
(Internal Ref TS-1503)
