With the inability to import files from PlanetPress Design into PlanetPress Connect, I am having the following difficulty in mapping sample data.
Today I use emulation of type “csv” with the text delimiter being " \0", indicating the end of a string. With that my data can be visualized row by row in the data page. In PlanetPress Connect I am not able to perform the same configuration.
Hello @Thales,
Can you let us know please in which version of PlanetPress Design this works fine and in which application (Designer or Workflow) and version of PlanetPress Connect this doesn’t work as expected?
Yes. I use PlanetPress Suite version 7.6.2. basically my sample data file is made up of N records where each line contains a user’s data. This data is selected and used in a document in Design that uses a .pdf file as a layout, just by entering this data in the fields.
I’m trying to reproduce the same result, still in the stabilization and emulation part of the data file in PlanetPress Connect Design v. 2022.1.4.10850, but this’s my result.
I cannot separately select my data, which are previously defined by their maximum number of characters that they can receive.
Solved, changed the properties of the page delimiters to “in lines”, the record limit to 999999 and cut the number of pages to 1
