Hi - can anyone help me with sending an email to multiple recipients and needing to show all in the ‘To’ field. Currently it will only show one recipient per email. I need to send an email to be able to show all the recipients so that they know who has received the email. I know I have to add the line X-MC-PreserveRecipients: true. This will ensure the behavior is applied only to the emails generated using this specific template. However, I do not know where/how I am supposed to use this.
Hi - thank you for the information. I checked with Mandrill last week on this also. Here is what they said - I haven’t gotten it working yet but incase this helps anyone else.
Add the Header in OL Connect: In the configuration settings for your email template within OL Connect, ensure that you include the header X-MC-PreserveRecipients in the Headers section of your email.
Set the Value:
• To hide recipients: Add the line X-MC-PreserveRecipients: false.
• To preserve recipients: Add the line X-MC-PreserveRecipients: true.
This ensures the behavior is applied only to the emails generated using this specific template.
Verify Header Placement: In the screen you provided, it seems headers like meta[name=email-cc] are being used. If you’re dynamically generating headers via scripting in the template, ensure the X-MC-PreserveRecipients line is included in the script block where the headers are defined.
Test the Setup: Once the header is added, send a few test emails to ensure the recipients are either visible or hidden as intended.
Can I ask what your script with the addHeader call looks like?
The code in the earlier link is a bit confusing since it uses JSON.stringify. There is no need for that, passing true should be sufficient: addHeader("X-MC-PreserveRecipients", true)
I have been trying to figure this out. I haven’t worked with emails that often. I do not where I am supposed to put the script. I know in the header but I guess I do not know where exactly.
The only way to include an SMTP header is through addHeader.
Adding a <meta> entry to <head> is useful in some scenarios but it won’t affect SMTP headers for email output. (I double-checked our code to make sure.)
