Dynamic Table Scripts
Using Connect 2020.1, the Scripts for Dynamic Tables no longer appear. Where are they?
With the coming on 2020.1, server-side script are no longer needed with the new data-field attribute which basically does what they were doing…but for you.
Now you might argue that you need to modify the content of what will be displayed and that too, was thought of and made so much more simpler. You now use data-script which, like data-field, is an attribute that links you cell content to a “content” to come. Place holder are still added on screen using the previous default format @placeholder@ but they are no longer needed.
to go from a data-field to a data-script, read the following.
Here’s a list of those new attributes.
That should get you started.
Where is the “data-field” pane? Ah… it’s the Field value in the Attributes pane… and then click the script icon next to it to convert it to a Script. I see. Thanks.
