Dynamic table position
How do I position 3 dynamic tables side by side?
Dear @khughes859,
Can you let us know please if you would like to let the three dynamic tables overflow in each other? The reason why I am asking this is because you will have to write some script for this as this is not possible by default and because in that case you may want to apply a solution similar to the example described in this OL Learn forum post. Please note that this example is about a ‘two column approach’ instead of ‘three column approach’.
Hello Marten,
Can you let me know how can I have 2 table that has are the overflow of each other on same page.
When the page overflow occurs ,that should be continued.
can you please share exact link for the guidance?
@Marten It would be great if you can help me with the above query. Its bit urgent.
Hello @djinkal,
As mentioned in my previous reply from back in 2024; to achieve this, you may need to apply something similar to the solution described in this forum post as this is not possible by default.
