I have a template design in which I have used dynamic table in section 2,When we try to map data it works properly but once we save it and close, the data on section2 gets static for dynamic table and other data binding on section2 does not work .
Can any one help me with handling the dynamic table. Is there any other way to keep the dynamic and save it for frequent use.
Hello @djinkal,
Can you let us know please in which version of OL Connect Professional you’re facing this issue? An option to check this is by going to Designer application > Help > About <Connect_Edition>….
We are using 2023.2.0 version @Marten
Thank you for sharing the version.
Does this issue also occur when you switch from Design mode to Preview mode and back again?
Have you applied the translation built-in feature* within your Template?
If the answer to both questions is “yes”, then I assume that you are facing the following issue which have been fixed in version 2024.1.2 of OL Connect:
Fixed an issue with switching from Preview mode to Design mode, if Translations are used in combination with ‘Evaluate Handlebars expressions’.
In order to fix this Preview mode is now read-only if ‘Evaluate Handlebars expressions’ is turned on. (90420)
Source: 2024.1.2 Release Notes - OL Connect 2024.1 Help
*See Translating templates - OL Connect 2024.1 Help for more information about this feature
Thank you for helping me with this.
The answer to your first question is Yes, When we change it to preview and then again go to design mode ,it happens.
We do not have used the translation built-in feature.
If I upgrade my version then will it affect my existing Datamappers and Templates? Will the templates made in old version work properly in new version?
I expect that they will work properly as long as you haven’t saved the Templates via the OL Connect version 2023.2.0 Designer application after the issue occurred.
