Hi
Have to put an overlay on a media in Designer
Tried to put the dynamic overlay on the print with the following script:
var resourceUrl = record.fields.Overlay;
printSections[‘Overlay’].background.source = BackgroundResource.RESOURCE_PDF;
printSections[‘Overlay’].background.url = resourceUrl;
record.fileds.Overlay holds the path and filename for the overlay pdf file like c:\Temp\Overlay.pdf
Problem is, that the overlay is placed in front of the letter and is not transparent – so the merge in the script is not an option.
If the same overlay pdf file is placed as a background (static image) on a media it is working 100% and is tranparent.
Is there a way to put the dynamic overlay on the media instead with a script?
It works if you put it in the Virtual Stationary?
If that’s the case, you can access the Virtual Stationary programatically, just like you’re doing with the print section’s background.
merge.template.media[“Media 1”].stationery
If I put the static overlay PDF file on a Media an control the different medias with a media script, the overlay is printed correct with tranparency.
But can’t figure out how to make a script where the pdf file used for the overlay is dynamic from the datamapper.
Thsi script only set the background on the print content page
Well, like I said, you need to access the Media, not the Print Section.
merge.template.media[“Media 1”].stationery.front.enabled = true;
var honorific = record.fields.Honorific;
if(honorific == ‘Mr’){
merge.template.media[“Media 1”].stationery.front.url = “images/BACK-M-LT.pdf”;
}else{
merge.template.media[“Media 1”].stationery.front.url = “images/BACK-F-LT.pdf”;
Above is a simplified example that has different backgrounds depending on the recipient’s honorific. If the path to your images is in the data, just substitute my image calls for your variable path.
