Dyamic Duplexing
Hi we have a section in Pres Connect that is a simplex template. But on this we can put a variety of PDF backgrounds some being 1 page and the other 2 pages.
Is there a way we can set the Duplexing options by the number of pages in the PDF?
Hello @timj1980,
Yes, there actually is.
Let’s say that you have applied an Extract step on the DataMapper configuration side and that this Extract step contains a field with name pageCount and that the JavaScript code steps.totalPages has been applied to this field. In this case you can apply something like the following to your Print Template:
Control Script
let printSection = merge.template.contexts.PRINT.sections["Section 1"];
let field = "";
let pageCount = 0;
field = record.fields.pageCount;
if (field !== "") pageCount = parseInt(field);
if (pageCount === 1) {
	printSection.sheetConfig.duplex = false;
} else if (pageCount === 2) {
Tip: Click with the right mouse button on the Control folder in the Scripts pane of the Designer application and go to New > Control Script to add new Control Script to a Print Template.
