Duplex Printing
Hi - I have a process where I already have pdf files created from several other processes. They are merged and sent to printer. Print sections are all set to duplex.
My question is how do I get my printer to print duplex if I take a pdf file and drop it into a folder. I currently pick that file up and send it directly to the printer. It isn’t going through and template or data mapper. I cant use the ‘Print using the windows printer driver’ plug in. I don’t think my printers have the right drivers. It just prints out error pages. This process print simplex only. I then created a document with a blank print section set to duplex. I selected that document in my printer queue output plugin. that doesn’t work either.
Any other suggestions?
Thank you
Hi @charleswhit,
First of all, welcome on our OL Learn forum!
Can you please explain what you mean by “I cant use the ‘Print using the windows printer driver’ plug in”? Does it raise an error message when you run the Print using a Windows Driver plugin or is the output still simplex for example?
