Is there anyway to disable the Submit button if connectivity is lost?
You will have to change you button type from submit to button and add the connectivity check in there.
If you have connectivity, then submit your form using the from id. $(‘#myForm’).submit
JQuery documentation says you could also use $(“form”).submit, but that did not work for me.
SA
