Hi, I am trying to use a conditional statement to determine what text should show in a positioned text box based on the value of a variable from my dataset. Does anyone have an example of what that code might look like?
There are many ways of doing. This is an example:
Alternatively read the text from a snippet. Have a look at this:
@hamelj Can I indent the text at all using your way?
@hamelj Or change the line spacing?
You may want to consider the solution as available in the link shared by @Erik, in case you want to indent the text or change the line spacing.
