Hi - I am creating a detail table and as the default the data is placed in columns. I understand that, however I am trying to get the data to go across in a row. My data is set up in a table with repeat data. See example below. Is there a way to switch the column and rows?
Currently the detail tables in Connect do not support horizontal output like this. You may be able to work around this with a significant amount of custom coding if you do require that format. If so I’d advise contacting your local support team so we can work with you on a solution
