hi everyone,
In design and preview mode, the screen looks smaller than the panel. Window>Reset Perspective did not fix it either.
Can you help me?
hi everyone,
Can you help me?
You’ll need to change some compatibility mode settings to handle the large resolution of your screen.
That should fix this up on the next launch.
Do you happen to have two screens of different resolution? I’ve seen this once before where the DPI Settings change doesn’t work if one screen is significantly lower resolution. In that case, they had a 4k monitor attached to a laptop with a pretty low resolution and had both screens displaying.
I run the program on the cloud server and connect with RDP.
Based on what you said, I’ll try some settings and let you know the result.
Thank You.
Best
Have you already tried the option: (Connect Designer) > Window > “Reset Perspective…”?
@Marten,
Yes , tried
The display of the HTML controls can be fixed by enabling a compatibility option on the Designer shortcut.
The HTML controls (i.e. the Welcome screen and the main HTML editor) should now be displayed as expected.
Please note that this is a workaround as high DPI displays are not currently natively supported. This means that, for example, the HTML content will be shown pixel-doubled and will not take advantage of the additional display quality capabilities.
