I have an excel sheet I need to read records from.
I know I can mount it as a DSN, but in this case I just used the a datamapper with the excel sheet as input.
I get a fine XML out of the datamapper.
Problem is when I put tags from the XML fil into Variables with “Set job Info and variables” i messes up the Danish letters ÆØÅ
I have tried to use the tranlater plugin, but still it messet it up.
XML from datamapper attached.
It is properly a XML data format quistion, I could use JSON as output form datamapper, I just don’t know how to split a JSON file into single records - there is no plugin for that.
Thanks in advance
Datamapper.xml (2.0 KB)
