Database query only from designer (without datamapper)
i was asked if it would be possible to make a database query only from the designer, without using the datamapper.
I only have used a database with a database-datamapper, and wihtin a script in datamapping, but never only in the designer.
So my question is, if this would be possible?
Many thanks,
N.Becker
Hello NBecker,
It is not possible to query a database from within a template. Are you producing content via OL Connect Workflow? In that case you could query the database as part of your flow and pass data in JSON format.
It’s possible from workflow ,
so my tested case we have two tables one master and other is details .
we connected to details table from data mapper and did logic and get other data from master table while processing the workflow .
I hope this help you .
