Hey all,
I have a problem where I require i dynamic table in designer based on a single row of data.
I have tried to use a repeat loop that would go over each field needed for each individual sub-table to no avail.
I have also tried to manually insert information via a script to the sub-table but i cannot create any more entries apart from the initial record.tables.sub_table_name[0].
ie.
record.tables.sub_table_name[0].fields[‘field’] = ‘data’;
record.tables.sub_table_name[1].fields[‘field’] = ‘data2’;
Problem above is record.tables.sub_table_name[1] is undefined. How do i define it?
Thanks in advance!
