I started learning Connect by creating a data mapper from a PDF but now my employer is asking me to work with a CSV instead. I created a model from the CSV and now I’d like to use that model to create a template in Designer. It’s been a little while since I worked with Connect and I can’t figure out why I’m not able to create a dynamic table to use with my model. The button is greyed out on my tool bar.
Dynamic Tables are only available if the loaded record set or data mapping configuration contains transactional data in one or more detail tables (see Loading data). Depending on the data, a Dynamic Table can also contain data from nested detail tables.
Note: Dynamic Tables cannot be used on a Master Page (see Master Pages).
