Create File Sheet Count Metadata Processes
Good afternoon, I would need to be able to generate a process with meta data. to know the number per minute of printed sheets. I have several processes corrected in ps and pdf…
This is at planetpress 2021.1
You will have to provide more information than that. If you are not comfortable explaining it in English, write it in your own language and use Google Translate before posting it here.
Also note that posting the same question in multiple forum categories is confusing to everyone, so I have deleted your other post containing the same question.
Hello, sorry for the misunderstanding.
The first consultation.
There is a way to obtain the number of sheets that were generated in a daily record. There are several workflow processes that run daily. Is there metadata to work with?
The other query is. Can ppw.log be written to the general log at the end of the process?
I leave you an example
New_XeroxB_Print_PRD1_010LE4MD4OJS78E (thread id: 7132) - 09:54:21
09:54:21.164 [0009] printing policy paper producer:
09:54:21.687 [0057] 3217IC-28010708 checkbook: 1
09:54:21.690 [0060] printing checkbook: 3217IC-28010708
New_XeroxB_Print_PRD1_010LE4MD4OJS78E (thread id: 7132) complete - 09:54:30 (elapsed time: 00:00:09.606) ---- > Add a string to this line
the workflow version is 2022.1.4
The query is like working with metadata, I have several processes PDF and ps generation . What I want to know is an example to be able to create a process that takes the data generated for the day from all processes, example number of sheets generated. Is this possible ?
