Can you let us know please what you mean by “stopped working”? Does a specific error occur by executing the provided JavaScript code by a Run Script Workflow plugin, for example?
Tip: I would advice to declare the variable totalDocuments outside the if-statement instead, as shown in the below modified version of the shared script.
var totalPages = 0;
var totalDocuments = 0;
if (xhr.status === 200) {
totalDocuments = job.length;
Looks like the localhost loopback is not enabled on your new server. You can test that theory by changing localhost to 127.0.0.1.
If that works, then you can simply use that IP address, but if you absolutely want to use the localhost name, you can follow the procedure outlined in this Microsoft Learn article.
That message is displayed by the scripting task when one of the JS Includes cannot be found or loaded. It’s only a warning, however, because not all scripts use all Includes all the time. Since your script doesn’t appear to be using any external modules, I don’t believe this warning is the cause for your particular issue.
However, you should still investigate why you get that warning because it might be a sign that your setup is not longer correct, which means previous tasks may have been unable to perform their job properly, which could account for this script failing.
Yes, but here the problem is that it considers an empty array, or rather an array with an empty string, that is incorrectly left by the installation process. Hence the message skipping: followed by nothing.
