I have a .txt data file with a field named Country at a fixed position. I try to get a report of all diverent occurrences within this field and the amount of occurrences per diverent "“Country”.
I loaded all the lines in the data file and placed all the country fields in an array (in Dutch):
I do this all the time using a script in Workflow. It is VBScript though and used for calculating postal codes. I modified it quick to accommodate your array and the output is written to a file as follows.
Option Explicit
Dim codesIn, codesOut, i, fullFile
Const ForReading = 1
Const ForAppending = 8
Dim fso : Set fso = CreateObject("Scripting.FileSystemObject")
Dim indexOut : Set indexOut = fso.OpenTextFile("D:\out.txt", ForAppending, True)
fullFile = Array("Nederland", "Nederland", "Nederland", "Nederland", "Duitsland", "Nederland", "Nederland", "Nederland", "Belgie", "Nederland", "Canada", "Nederland", "Spanje", "Nederland", "Duitsland", "Nederland", "Nederland", "Frankrijk", "Nederland")
ReturnArrayDupeCount fullFile,1
indexOut.Write(codesOut)
indexOut.Close
watch.log codesOut,2
Sub ReturnArrayDupeCount(aTemp, iShow)
Dim itemNameKey
Dim d : Set d = GetDupDict(aTemp)
For Each itemNameKey In d.Keys
codesOut = codesOut & itemNameKey & " " & d(itemNameKey) & vbcrlf
Next
Set d = Nothing
End Sub
Function GetDupDict(aTemp)
Dim dItems, j
Set dItems = CreateObject("Scripting.Dictionary")
For j = 0 To UBound(aTemp)
If Not IsEmpty(aTemp(j)) and Not aTemp(j) = " " and Not aTemp(j) = "" Then
dItems(aTemp(j)) = dItems(aTemp(j)) + 1
End If
Next
Set GetDupDict = dItems
Set dItems = Nothing
End Function
I thought you had that part done? You will need to load the data file via the script and load the countries into an array as you mentioned. In my case this script is part of a few scripts all of which consist of ±400 lines of code and in a previous script it wrote the values to a file and this script read that file and did the counts for each unique value.
I just spotted your post while I was on break and thought I would share my script to get you started. Unfortunately I’m a bit busy at work now. Perhaps someone here can help out and if I find the time I will try too.
