Have a data field I extract from a SQL DB, unfortently it is in string format
Format “yyyy-MM-dd HH:mm:ss”
I have to check if the date is higher than another date i a JScript in the workflow, the other date is in datetime format.
Any hints on how to get it to work ?
My Script:
var PDFCenter_FileDate = Watch.GetVariable(“LastDownLoadPDFCenter”); // Format “yyyy-MM-dd HH:mm:ss”
var PDFFile_UpdateDate = Watch.GetVariable(“LastDownLoadPDFFile”); // Format “yyyy/MM/dd HH:mm:ss”
PDFCenter_FileDate = PDFCenter_FileDate.date(PDFCenter_FileDate, “yyyy-MM-dd HH:mm:ss”);
if (PDFCenter_FileDater > PDFFile_UpdateDate){
Script.ReturnValue = 1; //SCRIPT TRUE - File needs update
else {
Script.ReturnValue = 0; //SCRIPT FALSE - No file update needed
It says Error on the if line, where I convert it to datetime.
