Retrieve items has got very slow on our dev server, is there a way for force a full clear down as we’ve been running jobs with 800k + pages through. Also how long are they kept for by default? I found the minimum settings in the server config but couldn’t see maximum
You can use Mark Connect Sets for Deletion after you’ve retrieved it or it is no longer of any use so that it gets removed the next time the database cleanup runs. Otherwise it’s removed on the schedule set in the server configuration.
If you want a completely clean database then just stop the Connect service, drop the objectiflune schema entirely and start the service up again and it should build it for you.
Hi @jim3108,
Can you share the steps on how to drop the objectiflune schema entirely, for the Connect version 2019.2.0.
Thank You.
It should be possible doing this:
Clear Connect DB manually - OL Connect Enterprise / General - Upland OL User community (objectiflune.com)
Regards
J.
