cleanup service connect\filestore operation
Good night. I have the following query, apply changes in the cleaning service which works correctly but problems appeared when generating pdfs (all in one) randomly there are pdfs in which the data re-rendering has some errors, for example the data is not re-rendered barcode, I wanted to know if this problem is due to this new configuration (changing the initial configuration from 1 day to 30 minutes) since with the default configuration the disk was full. The generation is carried out in several workflow processes and with different inputs, one of them is apart from the loading of an XML and others from https inputs. Greetings.
I suggest you open a technical support ticket through our website.
This type of situation will require an agent looking into your configuration and do tests with you.
Thank you very much for the response.
The time was increased to 10 hours and there are no longer problems regarding the rendering of elements in the forms.
Now the problem is in the space occupied by the files in the %USERPROFILE%\Connect\filestore folder. Is there a possibility of changing the address of that folder, for example, making it hosted on another partition other than the C: drive?
Thank you very much in advance.
Unfortunately, there is no project to chnage that for the moment.
