Does the new chromium engines in version in v2026.1 use more resource? I’ve mirrored the engine setup I had previously v2024.2 and when jobs are running it’s hitting 100% CPU usage way more than it used to and often makes designer etc unusable.
I can obviously change the number of engines, but just curious if this is a known thing, also obviously means jobs are going to take longer to run if I have less engines
