hi , may i know it is possible to change the value inside the postscript for the “id = splitInd”
i want to update the value if the text is match with “123”
Hi @john717,
In case you would like to change the value of the attribute “value” you can use a Post Pagination script, such as:
Selector #splitInd
var strValue = results.attr("value");
/* We use "===" instead of "==" because results.attr() returns a object
* ("null") when the attribute 'value' does not exist. */
if (strValue === "123") {
// Add your JavaScript code here...
//results.attr("value", "Hello World!");
In case you would like to change the inner HTML of the span element #splitInd then you can use a Post Pagination script, such as:
Selector #splitInd
var strValue = results.html().trim();
/* We use "==" instead of "===" because results.html() always
* returns a string. */
if (strValue == "123") {
// results.html("Hello World!");
