Change date format in workflow
I am trying to change the date format from 09/20/2020 to 20200920. I am using the following in order and it get the data the way I want it but once it leaves the branch the variable is gone… By gone I mean it isnt there any longer. data for is an xml.
In a separate branch -
create file = xmlget(‘/Participants[1]/Participant[1]/ChgDate[1]’,Value,KeepCase,NoTrim)
change emulation = line printer
advance search and replace = /
set job infos and variables = %6 = @(1,1,1,5,8,KeepCase,NoTrim)@(1,1,1,1,2,KeepCase,NoTrim)@(1,1,1,3,4,KeepCase,NoTrim)
change emulation = xml
output = delete
I see my variable is created the way I want it but then when it goes back to the main branch and finishes going through the process the variable disappears.
I know it must be something simple but I can not figure out why the %6 variable disappears. I only need the date format like that to use in the file name output.
Double-click on the branch itself and untick the “Backup job information” option. It is ticked by default, which means the JobInfos are restored to the value they had prior to entering the branch.
THANK YOU!!! Worked perfect now.
